Problems with Axis
It used to be when I created an object in Max and set the axis to the centre of the object, when I imported it into Daz the object would pivot on the correct axis.
Since 4.6.1.33 when I import the same objects that were ok, now the axis seems to have moved to the side of the bounding box.
Has something changed in Daz, there does seem to be new axis commands (or I hadn't seen them before)
Edit
Panic over - No idea what I did but the axis is now back in the correct place. Must have been a setting somewhere.
Post edited by jtbethel on
