problem with maps
I've the Corridor but the map doesn't load. I re downloaded last night and installed the map in 3 different folders trying to get studio to see it. It won't load onto the model.
Which Corridor, there are several of them, can you give a link please?
I may have the one you are referring to, and I can check the install for you.
http://www.daz3d.com/the-arc-sci-fi-corridor
Check install? I got this years ago and the template loaded fine. Don't recall deleting the map but it no longer loads. I used studio's content locator but no luck.
I have to login on each visit. But I noticed that the template file name - for (windows link) Sci Fi Corridor - has "Arc" as part. I'm wondering if that link is going somewhere else.
Put another way perhaps, which specific folder do I install the template file (if it's the right one?
Also, the Corridor appears in the content window in studio, tho without textures. But when I go into programs/daz/etc the Corridor is no where to be found. WTF?
Are you Hand installing content?
Are you loading the files from INSIDE DAZ Studio?
Are your Content path/paths set up properly in DAZ Studio?
Objects appear within Studio's content dialog. The map, wherever it is, did load at one time but no longer. Please link or type how to do the paths. The oddity is that everything else loads fine. And to be honest, I've the installed files is different folders; yet they still load. In the past, it appeared that the installer placed things into the pertinent folder (or the file scan found them). This wasn't the case with the Corridor's map however.
From another angle, I do a lot of stuff in Bryce, so have many object files in the Bryce 6 folder (tho they load in Studio!). I've had to Load things in Studio first to then bridge back to Bryce to get it into that.
How should I tidy this mess up? Thanks.
