Daz to Zbrush
Is there any way to get 2 chars to zbrush at the same time to make som morphs for grabbing arms and such ??? if i mark 2 chars and press export only one gets to Zbrush
Hope someone can help me
Thanks
  • Cris PalominoCris Palomino Posts: 13,020
    I don't think you want to do these as morphs as you would want what you're doing to be further modified with the normal bend and twist used for posing. How exactly are you thinking you want to morph and what parts?
  • KerwinKerwin Posts: 124
    Parent the second character to the first.   They will show up together as two subtools via GoZ.   When sending back, make the first the active subtool and press GoZ to send the morph back to DAZ.  After that select the second subtool in Zbrush and press GoZ again to send the morph for the second character.
    Alternatively, export each at base resolution and use Morphloader Pro.   Turn on “Reverse Defirmations” on reload if the character was posed before export.  Load one morph at a time.
    HTH
    edited June 2019
    Dup
    Post edited by Kerwin on
  • Hun73r3dxHun73r3dx Posts: 38
    Thanks that worked
