Difference Between "Ready Scene" Set and "Preload" Set?
In the Gamer Room set,
https://www.daz3d.com/fg-gamer-room-and-props
What's the difference between Ready Scene Set and Preload Set?
Similarly, in the Jacuzzi set, what's the difference between "Jacuzzi Deck !Preload Iray" Set and just the "Jacuzzi Deck Iray" Set?
https://www.daz3d.com/jacuzzi-deck
Please see attached screen shots.
500 x 432 - 42K
474 x 708 - 54K
  • NorthOf45NorthOf45 Posts: 5,920
    For the Jacuzzi, the "Jacuzzi Deck Iray" is the deck, the walls and the tub. A preload usually contains all of the props in a product, in this case, it adds a couple of chairs. A Ready set, or Ready-to-Render, has a preload and lighting/render settings and probably cameras, so you just load and you're, wait for it, ready to render.
  • Thank you, North.
  • ArathSinArathSin Posts: 10
    What is the use case for the preload?  Is it faster for maybe working with character poses/etc, then you delete the preload content and load the ready-to-render?
