Batch Editing Parameters
BejaymacBejaymac Posts: 2,014
I used to do a lot of batch editing of morphs with the old Property Editor, but since it got replaced I haven't been able to find any way of doing it with it's replacement, so could someone tell me how the hell we batch edit parameters now?
  • Richard HaseltineRichard Haseltine Posts: 112,065
    You should be able to multi-select in the Parameters pane in Edit mode.
  • BerBuzBerBuz Posts: 64
    What are the two new symbols beside the padlock in edit mode ?
    I see only one new symbol - the chain icon, which can be used to suspend ERC links so that the parameter is no longer affected by any other properties it is linked to, is there in standard mode though visible only if you have the mouse over the "title bar". The symbol that looks to me like a baby's bottle is to toggle on and off auto-follow - whether the property will be projected into fitted items or not.
    Thank you Richard :-).
  • zededd2000zededd2000 Posts: 111
    this might be a relevant place to ask...
    how can you move a group (and it's sub-groups) around like in the property editor?
    most the other features I used to use are there... a bit fiddly, but I hope i'll get the hang of it if I can just move some of these groups into 'the right order' after foolishly clicking 'sort property groups' and messing up the order :Z
