Will UV Tailor work with G8 figures?
daveso
in The Commons
when this was released, the newest figure was G3 ... would it work for G8?
https://www.daz3d.com/uv-tailor
G8 shares the same UVs as G3
Laurie
awesome
Why spend money on that plugin when the genesis 3 female seam guides/templates are free right here https://drive.google.com/drive/folders/16-1C2dpvJCj-e4EyEBLaCvmAmMfHSAKn
I have UV Tailor. I probably under-utilize it's capabilities even though I keep it docked. If you select the object in the Scene, and also select the object or one of it's material zones, the uv will show up in UV Tailor. I've done this many times with some of the silly things I've created using primitives.
That is an awesome resource, Michael. Thanks for the link.
It doesn't make UV Tailor obsolete, though, imo.
NP, I use Snows seam guides often which is why I had it bookmarked.
As for being obsolete, definately not, but if all a user needs are templates for items bought in the store including figures, they are usually in ones library or on the web so for that I don't see the need for it.
You can also select UV View from the list of cameras in Daz Studio (you know , that list in the viewport with Perspective, Front View, etc.). Then you can choose to display the UV for the selected node or selected material. I've been known to screenshot that for a quick template.
awesome..thanks both . will check these out.
