Daz Not Using My GPU?
asdf123asdf123 Posts: 167
Hi All,
My system is an i5-4690 + GTX 970 with 16GB RAM. I'm trying the IRAY Benchmark Scene, as well as simply adding G3F to an empty scene, and in both test renders DAZ seems to only be using my CPU (photo attached). If I disable CPU entirely from the Advanced tab, when I render, I just get a black screen as the output. Sounds like there's a problem somewhere, but I'm not sure how to go about solving. Any help would be greatly appreciated!
348 x 258 - 7K
  • no noseno nose Posts: 318
    I have a 1060 and having this issue as well, nothing I found has worked, DAZ seems to rely entirely on CPU and RAM expect for D-force
  • asdf123asdf123 Posts: 167
    I just updated my GPU drivers and it solved the problem, immediately. Forgot that I was on a reinstall and hadn't done so yet
  • Seven193Seven193 Posts: 1,156
    These kind of questions should begin with the Daz Studio version you have installed, as it requires a minimum nVidia driver version for hardware acceleration.
    Thanks for reminding me to do that,though it doesn't seem to have made a difference
