How to Remove Dress Handles
I have recently purchased this Back to Seventies dress https://www.renderosity.com/mod/bcs/?ViewProduct=104923
It works just fine on G2F, regardless of the fact it was created foir V4. However, one thing I can't get around is some small balls/handles that form a circle around the dress. I tried tocontact the creator, but haven't heard back from them. Any ideas about how to make them invisible. They serve no purpose anyway. I rememeber there was a hair item with similar handles but they worked to move some strands around. These balls don't do anything. Thank you.
314 x 410 - 36K
  • LeanaLeana Posts: 13,514
    They might have a specific material zone in the surface tab that you could make transparent, or you could create one with DS geometry editor.
  • https://www.daz3d.com/forums/discussion/304091/released-rssy-clothing-converter-from-victoria-4-to-genesis-8-female-commercial/p1
    If you go to the first post, one of the creators made a script to hide pose handles.  They made it for the RSSY clothing convertor.  It's the last two things under all those pictures.  I missed it the first few times.  Just download it and put it in your script folder and then open Studio and it should be there.  But the other thing is to make the surface invisible.  This was in response to my question:
    1. You need to hide the surface handles from rendering.  Usually, there is a surface called "Handles" or similar.  Find it, and then set Cutout Opacity (Iray) or Opacity (3DL) to 0%.  I've gotten annoyed hiding those things so I made up a couple scripts to hide/show any material with the word "handle" in it in the scene.  You're welcome to use them.  They are available at the top post of this thread.
    So I used the surface tool and then rummaged around until I found some part that was the handle.  Or pose control.  Then I found the slider on the surface tab to make it disappear.
  • D OvD Ov Posts: 104
    thank you guys! Will give it a shot
