Reconnect Plugins to 4.11?
DekeDeke Posts: 1,636
Downloaded 4.11. It seems to have found my content and even load scenes created in 4.10 flawlessly. But there's no keymate/graphmate. How do I relink those plugins to 4.11? Can I have plugins linked to both 4.10 and 4.11 in case I need to use both versions of Daz?
  • L'AdairL'Adair Posts: 9,479
    How did you install 4.11?
  • DekeDeke Posts: 1,636
    Downloaded and installed.  Not through Install Manager.
    I've checked my installed files, and there is a graphMate.dll and keyMate.dll in the plugins folder for both my released version install and my beta install.
    You mentioned you downloaded 4.11. That implies you did a manual install. If you installed 4.11 to it's own directory so you could keep 4.10 as well, you will probably need to copy the dll files for graphMate and keyMate in the Plugins folder from the 4.10 install into the Plugins folder of the 4.11 install.
    You may also find other plugins that need their DLLs copied over, as well.
    Thanks. That did the trick. Just copied the files over to the plugins folder and am back in business in 4.11
    You're welcome, @deke. I'm glad I could help.
