dForce Hair length manipulation
Hurdy3DHurdy3D Posts: 1,110
Hey,
if I remeber right it should be possible with the new dforce hair to control the hair length. I just bought Eddie hair:
https://www.daz3d.com/dforce-eddie-hair-and-goatee-for-genesis-8-males
Any tip how to make these hair longer?
  • Oso3DOso3D Posts: 15,120
    You can adjust Scale or Reduce length.
    Scale adjusts the overall shape bigger or smaller, reduce length essentially ‘cuts’ the hairs shorter.
  • Hurdy3DHurdy3D Posts: 1,110
    sadly, there is no "scale length"... and the length parameters shown in the screenshot had no effect
    492 x 973 - 57K
    PS and PR Generated Hair Scale
    Hey Oso3D,
    thank you that did the trick!
    To bad that's the Hair Scale setting is a dForce (surface) setting. Otherwise we could do pysically animated hair growth clips.
    But after surface settings are not affacted by the timeline... :(
    However, any advice how to get the extended hair to fall down, in the simulation?
    1000 x 1000 - 941K
    1000 x 1000 - 2M
  • OdaaOdaa Posts: 1,548
    Under dforce surfaces, consider messing with stiffness and simulation strength. I don't know too much about this new dforce hair stuff, but in the cloth version of dforce those are two of the less troublesome controls that control the fall/drape.
  • 3Diva3Diva Posts: 12,058
    edited June 2019
    gerster said:
    Hey Oso3D,
    I don't have that hair yet so I can't check, but with the dForce Mohawk that comes with the dForce Escentials I know that if you turn the "Local Shape Constraint Stiffness" way down to like .03 it will lay down with the simulation. I don't know if that's the "right way" to do it or not, as I haven't had much chance to work with the dForce hair yet, but it seemed to work when I experimented with it a little bit. :)
    238 x 324 - 28K
    Post edited by 3Diva on
    nope, Local Shape Constraint Stiffness didn't do the trick wink
    Weird. It worked on the dForce mohawk. :( Sorry, I wish I could be of more help. I don't have any of the purchased dForce hair yet so perhaps they're different.
  • KerwinKerwin Posts: 124
    What’s the difference between PS and PR?
  • Richard HaseltineRichard Haseltine Posts: 111,666
    You should be able to see the full names in the property groups, sorry I can't check or take a screen shot just now.
    Pre Simulation and Pre Render parameters
    Thank you.
    You gave me the clue where to find it.  ;)
    Thank Rob :)
