Quick way to increase size of a clothing prop?
I've figured out how to export clothing and adjust it in another app and import it back into DS, but I have one outfit that I simply want to make 1% bigger so it doesn't cling to the actor.
I don't want the shape of the actor to change, only the outfit (it's too tight). I don't need to adjust individual parts, just a slight increase in overall size would work.
Is there a simple way to do this directy in DS without a lot of exporting and importing?
  • NorthOf45NorthOf45 Posts: 5,900
    edited June 2019
    Edit -> Figure -> Geometry -> Add Push Modifier. This will allow you to add a small increment to the overall shape.
    Not so quick, but for more control, Create -> New Push Modifier Weight Node and use the Node Weight Map Brush to tailor the effect.
    Post edited by NorthOf45 on
  • jpetersen1jpetersen1 Posts: 148
    That worked. Thanks!
