Updated to 4.11 & now can not render (Solved)
billyben_0077a25354billyben_0077a25354 Posts: 771
edited June 2019 in The Commons
Well, I just shot myself in the fooot.  Updated to 4.11 without setting s restore point and now can not render.  Gettting errors all ove the place in the log file  Just giving every one a heads up to hold up for a few days on their update.
Here is what I got when clicking the render button  It can not find my 1070 even though it is checked..  Going to dry updating my driver first but baring that something is definately wring with 4.11
2019-06-12 20:36:54.737 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating geometry.
2019-06-12 20:36:54.738 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Using built-in ray tracing (1.0.0).
2019-06-12 20:36:54.738 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Importing scene graph.
2019-06-12 20:36:54.771 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Auto instancing compression ratio 1.00 (Full instancing compression ratio 1.00)
2019-06-12 20:36:54.775 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Importing geometry for motion time 0
2019-06-12 20:36:54.853 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Geometry import (1 object with 527k triangles, 1 instance yielding 527k triangles) took 0.077697
2019-06-12 20:36:54.853 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating materials.
2019-06-12 20:36:54.862 Iray INFO - module:category(MATCNV:RENDER):   1.0   MATCNV rend info : found 99 textures, 0 lambdas (0 unique)
2019-06-12 20:36:54.868 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Emitter geometry import (1 light source with 2 triangles, 1 instance) took 0.00s
2019-06-12 20:36:54.868 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating environment.
2019-06-12 20:36:54.877 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating backplate.
2019-06-12 20:36:54.879 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating lens.
2019-06-12 20:36:54.879 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating lights.
2019-06-12 20:36:54.883 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating object flags.
2019-06-12 20:36:54.883 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating caustic portals.
2019-06-12 20:36:54.883 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating decals.
2019-06-12 20:36:54.922 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Allocating 1-layer frame buffer
2019-06-12 20:36:54.968 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Using batch scheduling, caustic sampler disabled
2019-06-12 20:36:54.972 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(302): Iray ERROR - module:category(IRAY:RENDER):   1.0   IRAY   rend error: Cannot render: found no usable devices.
2019-06-12 20:36:54.972 Iray Render error: Invalid parameters (NULL pointer).
2019-06-12 20:36:55.322 Saved image: C:\Users\GP40X\AppData\Roaming\DAZ 3D\Studio4\temp\render\r.png
2019-06-12 20:36:55.328 Finished Rendering
2019-06-12 20:36:55.358 Total Rendering Time: 1.56 seconds
Post edited by billyben_0077a25354 on
  • melaniemelanie Posts: 807
    My sister is having the same problem. She tried rebooting the computer, no luck. Uninstalling DAZ and reinstalling, still no luck. Now she's in the process of restoring to an earlier point in time, but it's taking forever. They should have made sure things like this don't happen before it's released.
  • HavosHavos Posts: 5,707
    I had the same issue with a newer version of 4.11, however when I updated my nVidia drivers, rendering worked just fine.
  • Yes that was it.  Updated to the latest Nvidia driver and can now render yes
    How does one update the Nvidia driver? Mine works fine and I can render, but I think others may have this issue.
  • Avid RendererAvid Renderer Posts: 1,218
    The drivers are probably available in their website. I haven't updated mine.
  • dougjdougj Posts: 92
    https://www.nvidia.com/download/index.aspx
  • OcelianeOceliane Posts: 65
    I encounter the very same issue. Upgraded to 4.11, and even after updating all Nvidia drivers I still get these errors:
    2019-06-15 18:52:26.695 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(302): Iray ERROR - module:category(IRAY:RENDER):   1.0   IRAY   rend error: Cannot render: found no usable devices.
    2019-06-15 18:52:26.700 Iray Render error: Invalid parameters (NULL pointer).
    I upgraded to the last drivers (430.86) on my GeForce GTX 1060, and it now refuses to render. I even chose the game ready or the studio configuration, nothing changed.
  • Richard HaseltineRichard Haseltine Posts: 111,984
    What, if anything, is checked in the Advanced tab of Render Settings?
    Photoreal Device: GeForce Checked
    Interactive Device: GeForce Checked
    OptixPrime Accelaration: checked
    In both cases, CPU is left unchecked. That setting worked perfectly fine in 4.10, but still refuses to operate in 4.11. It instantly finishes the render.
    Have you tried disabling OptixPrime?
    I tried disabling OptixPrime, nothing changed.
    Here are the logs:
    2019-06-16 17:33:12.544 Rendering image
    2019-06-16 17:33:12.626 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating geometry.
    2019-06-16 17:33:13.161 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Using OptiX Prime ray tracing (5.0.1).
    2019-06-16 17:33:13.161 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Importing scene graph.
    2019-06-16 17:33:13.169 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Auto instancing compression ratio 1.00 (Full instancing compression ratio 1.00)
    2019-06-16 17:33:13.169 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Importing geometry for motion time 0
    2019-06-16 17:33:13.170 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Geometry import (1 object with 2914 triangles, 1 instance yielding 2914 triangles) took 0.000643
    2019-06-16 17:33:13.170 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating materials.
    2019-06-16 17:33:13.178 Iray INFO - module:category(MATCNV:RENDER):   1.0   MATCNV rend info : found 2 textures, 0 lambdas (0 unique)
    2019-06-16 17:33:13.178 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Emitter geometry import (1 light source with 2 triangles, 1 instance) took 0.00s
    2019-06-16 17:33:13.178 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating environment.
    2019-06-16 17:33:13.178 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating backplate.
    2019-06-16 17:33:13.188 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating lens.
    2019-06-16 17:33:13.188 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating lights.
    2019-06-16 17:33:13.188 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating object flags.
    2019-06-16 17:33:13.188 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating caustic portals.
    2019-06-16 17:33:13.188 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating decals.
    2019-06-16 17:33:13.204 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Allocating 1-layer frame buffer
    2019-06-16 17:33:13.215 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Using batch scheduling, caustic sampler disabled
    2019-06-16 17:33:13.215 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(302): Iray ERROR - module:category(IRAY:RENDER):   1.0   IRAY   rend error: Cannot render: found no usable devices.
    2019-06-16 17:33:13.215 Iray Render error: Invalid parameters (NULL pointer).
    2019-06-16 17:33:13.301 Saved image: C:\Users\Username\AppData\Roaming\DAZ 3D\Studio4\temp\render\r.png
    2019-06-16 17:33:13.307 Finished Rendering
    2019-06-16 17:33:13.354 Total Rendering Time: 0.90 seconds
    Please post a screen shot of the Advanced tab of Render Settings.
    Here is my configuration. With this, tne render instantly finishes with only a blank canvas. If I want to render, I have to check "CPU". Weirdest part is that after doing a few CPU render, if I uncheck CPU, it will sometimes detect my GPU and the render will go fine.
    Once again, this issue appeared after upgrading to 4.11.
    455 x 921 - 32K
  • AlmightyQUESTAlmightyQUEST Posts: 2,006
    Does it work for the first gpu render, it does it have to start with a cpu render? I've been having an issue where I can get one render out of a season, then get blank canvases (mine are black, maybe it's draw dome being on?) Until I close studio and open the task manager to kill the process. Then when I reopen studio I can get one more render. Sometimes I need to do a full system restart though. It's obnoxious and I haven't gotten any advice to fix it, so one I finish what I'm currently working on I'm planning on going back to 4.10.
    I always have to start with one or a few CPU renders. Yesterday, I was unable to get the GPU to work, while some other time it's fine.
  • alphawiz1alphawiz1 Posts: 8
    2019-07-23 09:52:03.454 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating lens.
    2019-07-23 09:52:03.454 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating lights.
    2019-07-23 09:52:03.455 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating object flags.
    2019-07-23 09:52:03.455 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating caustic portals.
    2019-07-23 09:52:03.455 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating decals.
    2019-07-23 09:52:03.460 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Allocating 1-layer frame buffer
    2019-07-23 09:52:03.463 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Using batch scheduling, caustic sampler disabled
    2019-07-23 09:52:03.463 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(302): Iray ERROR - module:category(IRAY:RENDER):   1.0   IRAY   rend error: Cannot render: found no usable devices.
    2019-07-23 09:52:03.464 Iray Render error: Invalid parameters (NULL pointer).
    2019-07-23 09:52:03.525 Saved image: C:\Users\jeff\AppData\Roaming\DAZ 3D\Studio4\temp\render\r.png
    Updating NVidia drivers did not work for me.  Anybody know where I can download a copy of 4.10 Pro still?
  • TheKDTheKD Posts: 2,711
    Be careful with killing the task, the reason it's still running might be it's running cleanup on temporary files and things like that.
  • LeanaLeana Posts: 13,641
    4.10 is not available for download anymore now that 4.11 General Release is out. You can try contacting Daz support to see if they can provide you with a copy,
