Issue with EJ Body Shape and Detail Morphs
CometsComets Posts: 87
I bought and installed EJ Body Shape and Detail Morps yesterday. Now one of these morphs, 'Upper Abs Only' is being dialled in on characters in scenes I saved before I bought the product. I have never used this morph before.
I dialled it to 0, but instead of disappearing from the list of currently used morphs it persists.
I shaped a new character subsequent to installation of the morph package and even used one of the EJ morphs. I did not use 'Upper Abs Only'. When I open the saved scene the 'Upper Abs Only' morph is absent.
Is this a bug? Can anyone suggest how I can get rid of the 'Upper Abs Only' morph?
  • Cris PalominoCris Palomino Posts: 13,034
    Do you see the morph on the figure in Currently used? Are you getting any warning when you load the scene with your figures? Did you load a fresh figure and does it happen to the new one?
  • CometsComets Posts: 87
    Yes, I see the morph in Currently Used.
    There are no warning messages when I load the scene with figures.
    After further testing it appears the morph appears when a pose is applied to the figure. I loaded a new scene, loaded base Gen 8 Female. No changes at all to the base figure. Applied a pose and the 'Upper Abs Only' morph suddenly appears in the Currently Used list. Perhaps this is why the morph doesn't disappear from Currently Used when it is dialled to 0 like other morphs - because the pose was still applied?
  • Richard HaseltineRichard Haseltine Posts: 111,860
    That morph is linked by addition to the Abdomen Upper Bend and to the Body Rectangle shape, so it kicks in when either is applied - I wonder if one of those should be multiplying rather than adding, so it shows only when both are set. You could open a Technical Support ticket to query this. In the emantime just zeroing it will clear the effect, it's showing as used becuase it has a non-zero local value to offset the non-zero value from the bend.
    Thanks all, appreciate the help. I'll lodge a ticket.
  • EmmaAndJordiEmmaAndJordi Posts: 952
    We have an update ready, and it will be soon available :)
    Brilliant, thank you. smiley
