CS Raptoid in Daz Studio ...
dramenon
http://www.daz3d.com/cs-raptoid
So what is the magic sauce to get this to work?
This is not a well delivered model and my first encounter with such an issue...
Thanks.
Post edited by dramenon on
A link to the product would have been better, as your link only sends me to my own product library.
This is a very old product, and will probably be found under Poser formats.
Updated link.
Finding is not the issue applying the injections is...
According to the Product Page, there are 5 INJ/REM Morphs, and 17 Facial and Body Poses, what ones are you having a problem with?
The more information you supply, the easier it will be to help you.
Trying to use this in Daz Studio 4.6.x, on Mac.
The file appears in the Library but looks to be old .ds format > // DAZ Studio version 2.3 (maybe should be removed form the store)
I wonder if this Morph requires a legacy figure? M4?
Will it work with a Genesis Fig? Does not seem likely.
There are no Dials, No Morphs to be found > simply nothing seems to be added anywhere in the UI.
This is the first time I have encountered such content, usually there are workarounds. But none yet...
The files are in Poser Format, and the Product Page says : •17 Facial and Body Poses (.PZ2)
You will find them in the Content Library > Poser Formats > (Your Library Name) > Pose. The same will apply to the 5 INJ/REM morphs.
It also says this:
So it is a stand alone figure, and will not 'apply' to any other figure.
Thanks for your help, I appreciate the additional ideas.
Looks like some of the content is in the Shared Library. Maybe the figure did not install > via the install Manager.
What did install that is in my library requires that mesh.
At this point I am ready to call it day, and I'll take it up with Daz team as they are quite reasonable in these cases.
That's the error you get when you try to apply a D|S pose/material/whatever script either to a figure that doesn't exist in the scene because you haven't loaded a figure into the scene yet, or the figure isn't selected. Looking at the store page, you have the D|S materials in the D|S content and the Poser figure in the Poser content — you'll never find the figure among the D|S files because it isn't there.
Edit: I just remembered a couple of weeks ago, someone discovered another split Poser/D|S format item that the Install Manager only installed the D|S files, there was a glitch stopping the Poser files being installed if you only use D|S. Maybe you've found another one with the same glitch?
Thank you, for the info!
