apply characters and sub-characters
When you buy a character that for example requires another basic character to work what does it mean? that if I hadn't installed that basic character, that character would not work? for example, I have Victory 8, so I have characters that require Victory 8. What should I do? should I first stage genesis 8 and then add Vittoria 8 and then the character? Or I can apply the character without the need for victory 8. I hope that with my bad English he can make me understand the same. Thanks for your kind response
  • 3Diva3Diva Posts: 12,058
    Most characters that say they "require" another character use some of that character's morph (either the head morph or body morph or both - and it will vary from character to character how much of the "required" character's morph is used). If you don't have the "required" character you can still use the other character that requires it, but it just won't look the same. There should be no need to "stage" anything just load the character (either from the Smart Content tab or from the Content Library tab) only the morphs you have installed will be available, so you might get an error message when you load the character if the required character isn't installed, just ignore the error message. :)
    Again though the character can look quite different without the required character, depending on how much of the required character's morph is usually used with the character. Sometimes the character looks fine without the required character, other times it will look pretty bad, but it will vary.
  • dannagiusy64dannagiusy64 Posts: 477
     Thanks, this was a question I always asked myself. Now I understand ... Thank you smiley
  • MazhMazh Posts: 505
    edited June 2019
    You have to be careful if you're using previous generations, these Daz base characters use (mostly) different UV maps, not having the matching UV map results in weird looking textures.
    Here's a render with the original Bethany 7 skin on a G3F without having/ using the Bethany 7 UV map, but it depends, if you see a character which is made for Bethany 7 e.g.,
    but there's something in the description like "This character uses the G3F Base Mesh", you are safe (except for the morphs).
    1080 x 1440 - 161K
    Post edited by Mazh on
    Thanks smiley
    Quando compri un personaggio che per esempio richiede un altro personaggio base per funzionare cosa significa? che se non avessi installato quel personaggio base, quel personaggio non funzionerebbe? per esempio, ho Victory 8, quindi ho caratteri che richiedono Victory 8. Cosa dovrei fare? dovrei prima mettere in scena la genesi 8 e poi aggiungere Vittoria 8 e poi il personaggio? Oppure posso applicare il personaggio senza bisogno della vittoria 8. Spero che con il mio pessimo inglese riesca a farmi capire lo stesso. Grazie per la tua cortese risposta
    La maggior parte dei personaggi che dicono di "richiedere" un altro personaggio usa un po 'del morph di quel personaggio (o morph testa o morph del corpo o entrambi) e varia da carattere a personaggio quanta parte del morph del personaggio "richiesto" viene usato). Se non hai il carattere "richiesto", puoi comunque usare l'altro personaggio che lo richiede, ma non avrà lo stesso aspetto. Non dovrebbe esserci alcuna necessità di "mettere in scena" qualcosa, basta caricare il carattere (sia dalla scheda Contenuto intelligente o dalla scheda Libreria del contenuto) solo i morph che hai installato saranno disponibili, quindi potresti ricevere un messaggio di errore quando carichi il personaggio se il carattere richiesto non è installato, ignora semplicemente il messaggio di errore. :)
    Anche se il personaggio può sembrare molto diverso senza il carattere richiesto, a seconda di quanto del morph del personaggio richiesto viene solitamente usato con il personaggio. A volte il personaggio sembra bello senza il carattere richiesto, altre volte avrà un aspetto piuttosto brutto, ma varierà.
