Girl 6 Works Victoria 6 Doesn't
DarkElfDarkElf Posts: 528
Ok. Can't figure what I am doing wrong here.
Background information:
Poser Pro 2014 with latest SR
Latest DSON installed
I got the Girl 6 and Gensesis 2 Female & all Morphs a few weeks ago. It took a bit of fiddling but I got them to work nicely with Poser.
Yesterday I purchased the Victoria 6 Pro Bundle and installed everything the EXACT same way as I did Girl 6 and Genesis 2 Female.
Victoria 6 WILL load - seemingly fine - but only SOME of the clothing that comes in the Bundle will properly conform to her when loaded.
I will make this simple with this simple example:
I load V6 - then the V6 String Bikini. The bikini top conforms fine to V6, but the bikini bottom only partially conforms. It is imbedded into her abdomen.
HOWEVER, when I load Girl 6 and then load the V6 String bikini, BOTH pieces conform to Girl 6 PERFECTLY.
I cannot figure out why the V6 String Bikini will properly fit Girl 6 but NOT V6. It seems like V6 must not be installed right - don't know.
Does ANYBODY out there know of a simple step-by-step process available out there that properly explain the correct installation of Genesis 2 related items to get them to work in Poser?
There seems to be very little documentation available to make Genesis or Genesis 2 work easily and painlessly right for Poser users.
  • Richard HaseltineRichard Haseltine Posts: 111,363
    edited November 2013
    It may be that the bikini bottom doesn't have a custom morph for V6 - does it help if you go to Scripts>DSON Support>Transfer Active Morphs? The top, and G6, being more different from the base may need custom morphs because the transferred morphs aren't good enough, while the bottom on V6 is fine.
  • DarkElfDarkElf Posts: 528
    Hello Richard.
    Thaks for the reply.
    No, I have tried that numerous times with no effect.
    But, thank you for trying to help me. :-)
