I just bought Z Picnic time props - need help
JENR8JENR8 Posts: 100
[I just bought Z Picnic time props - need help] I was hoping that the cups would seperate and that one single red solo cup (or blue in this case) could be used. Does anyone know if they can be seperated and/or if there is a red plastic solo cup model free anywhere if not?
  • Richard HaseltineRichard Haseltine Posts: 111,363
    Depending on how they are modelled you might be able to use the Geometry Editor tool. Select the stack of cups, then activate the Geometry Editor from the Tools menu. Click on a cup that looks complete to select one of its polygons, then hold down cms (Mac)/ctrl(Win) and press the * key to select all connected polygons. if that selected the whole cup and nothing but the cup then you can right-click>Geometry Visibility>Hide Un-Selected Polygons, right-click>Geometry Editing>Delete Hidden Polgons, then hide (or delete) everything else, File>Export as OBJ, File>Import (make sure you use the same preset in the options dialogue each time), and apply the materials to the imported item.
  • JENR8JENR8 Posts: 100
    I will look into it. Thank you so much!
