How to make a favorites list of morphs to transfer into clothing
in The Commons
Hi
Can you tell me How to make a favorites list of morphs to transfer into clothing?
Cheerio
lululee
You can click the heart icon on the slider to set the morph as favourit or you could right-click the Parameters pane select Edit Mode and now you can select multible morphs with Ctrl+click or Shift+click, then right-click on one of the selected and choose Mark As Favourit from the menu to mark all selected at once.
Next if not already unfit the clothing: Scene pane right-click Fit To: None. Then open the Transfer Utility, I am used to use a toolbar icon but I think it is also found somewhere in the main menu Edit>Figure.
In the Transfer Utility dialog select Source: genesis figure and Target: clothes, uncheck all General Options but check Morph Targets and as you select it there will be Extended Options showing on the right select From Source: Favourits and Sub-Components. Keep the both checkmarks From Projection Template and Overwrite Existing checked as they are. I would leave the Projenction Options at their defaults. Post Transfer Options are optional. Finaly press accept - done. The screenshot below is just for reference and not showing the settings as desciped.
HI Syrus_Dante,
Thanks so much for your really valuable info. I really appreciate it.
I apologize for not posting sooner.
I was away from the computer.
Cheerio
lululee
