Is There A Reason The HDRI In A Scene Is Not Saved?
Is there a reason the HDRI is not saved when saving a scene file?  I ts very frustrating to load a scene and have no idea what HDRI I finally chose after trying out 20 or 30 for a scene (I use the Iradience Light Probes alot and have all the extentions, which is at least a couple hundred.  And yes, I will go through the whole list on occasion
  • AlmightyQUESTAlmightyQUEST Posts: 2,006
    Are you opening or merging the file? When I open a file, environment settings are loaded, if I merge into a scene they are not.
    Otherwise I guess the questions would be, what version of Studio, and does this happen to every scene file or only sometimes.
    Nope just opening and I use both 4.10 and the Beta version and it happens in both.
  • TaozTaoz Posts: 10,346
    edited June 2019
    It does save the HDRIs for me, in 4.10.0.123. At least if I load it manually as Environment Map, don't know if there are other ways to add it. If it can't find the HDRI when I load the scene it asks for it.
    Post edited by Taoz on
    edited June 2019
    Try to check the settings under Preferences > Scene, maybe it's set not to save or load Render Settings. If the settings look OK, try to change them, then apply, then change them back and apply again.
  • FishtalesFishtales Posts: 6,232
    Go to the Edit menu and under Preferences/Scene make sure the 'Record settings when saving a scene file' are checked.
  • Richard HaseltineRichard Haseltine Posts: 111,371
    and that the option to Ignore reder settings on load isn't checked.
    I hadn't thought to mention those as I have them all unchecked :)
