Victoria 4 help fitting Bucanner - BonnieAnnesLocker clothing? Please help.
I can't get the clothes for Buccanner to fit Victoria 4 after downloading V4, new at this sorry. I'd like to
add that the clothes for BonnieAnnesLocker aka Buckaneer are showing up under Victoria 4 however
it's not attaching the clothes for some reason.
Post edited by icequeen22 on
You nned to load Buccaneer first. Bonnie Anne's Locker is an alternative texture set for Buccaneer, it is not the clothes
Is this the item that you have installed : http://www.daz3d.com/v4-buccaneer
I think you are probably trying to load the DAZ Studio materials, it says on the Product Page:
The actual clothing is in Poser format, and you will find it in the Content Library under Poser Formats > My DAZ 3D Library > Figures.
EDIT:
XPost, too late, thanks Pam.
Ahhh It Works! Thankyou i was going nutty trying to figure that out,
many Regards Pam!
Jane
EDIT:
One more thing here, Yes i did add V4 buccaneer, and i also added this one
http://www.daz3d.com/bonnie-annes-locker
however the second will not work, the clothes are there but won't attach to V4, and the
link you added above works fine? hmm Any suggestions i have booted it and nothing.
Thanks for your reply, I have loaded Buccaneer and it worked fine,
and this set of clothing i purchased
below http://www.daz3d.com/bonnie-annes-locker
will not load at all. I'm guessing the second set of clothes are only for use in Poser?
This is a texture set only for V4 Buccaneer, there is no clothing in this package, just textures for V4 Buccaneer. You MUST load Buccaneer first, select it in the Scene pane, then apply the texture set.
Thankyou for your help, i've got it figured out now.
jane
