Applying built-in Daz 4 Toon shader to single objects
ChromaDrakeChromaDrake Posts: 288
Is there a way to apply the cartoon shader build into DAZ 4 to a specific object in a scene, rather than the whole scene? I would like to combine it with PWToon using PWtoon for some objects and the cartoon shader for others.
Any help would be great! Thanks!
  • Richard HaseltineRichard Haseltine Posts: 112,037
    The toon mode will have no effect on surfaces that use pwToon (or any shader other than DAZ Default Shader). What the option does is tell DS to use alternative code on surfaces using the DAZ Default Shader.
  • ChromaDrakeChromaDrake Posts: 288
    Ah, ok! Thanks for the info.
