Problem with Drago Hair - renders empty scene
Ulysses0302
I just bought the new Drago Hair and so far I never had any issues using the dForce hair assets for G8F. The hair loads just fine and the simulation worked too but then the problems began:
- When I tried to get an Iray preview, the scene I got was empty. Both characters were still there because they became highlighted when I moved the cursor over them.
- Rendering the scene causes Daz to render for about 5 minutes, do about 35 iterations and then jump directly to 100% and finished render: An empty space.
- As soon as I make the Drago Hair invisible, the Iray preview works again
I'm a bit at a loss here as to what could be causing this since I never had any issues with any kind of hair assets, dForce or static.
That's weird.... did you try restarting the program? This hair's a bit beefy as hairs go. I've seen the happen with program once or twice and it cleared up after I saved and restarted then reloaded the file.
