HELP required please, with V4
madmadmad2040madmadmad2040 Posts: 44
usually i use genesis figure and those based on it since working with daz, of-late i was working with v4 . i made a female figure out of her with some morphs. i bought some new morphs which iam not able to inject them to my new figure where as they work fine with newly loaded v4. so i wanted to transfer all my dialed morphs of desired figure to freshly loaded v4. usually with genesis i can store as a character preset and load it but i am not able to do that with this. note this figure uses lali's bits a genital system from renderotica.
please help how can i go about
  • frank0314frank0314 Posts: 15,094
    How are you saving it?
  • madmadmad2040madmadmad2040 Posts: 44
    as a scene
    Unlike Genesis, V4 uses injection channels. If the channels are already taken up by previously injected morphs, you cannot inject other morphs into those channels. This is why you can load the new morphs into a fresh V4.
    As a side note, when you installed the new morphs, did you try running the initialize script again? Sometimes when you install new morphs sets you should run it.
    yes i ran it. now if i want to load my dialed character to a fresh v4 how do i do that
  • carrie58carrie58 Posts: 4,171
    edited November 2013
    I would try saving your V4 character as a character preset,you said you have her saved as a scene right now,so try to save as a character preset...... then you could just apply her to a new V4 figure ...........don't save her over your scene,so you will still have her as a saved scene oh and the "extra " parts would have to be add on separately ...
    Post edited by carrie58 on
    thank you brother for reply.
    but that's what was the problem that i could not save it as a character preset like i would any genesis figure.
    nevertheless i dialed every morph and achieved what i wished for.
