Hair and clothing turning skin green
Hi, I am having problems getting hair and some clothing to fit correctly. I am using Iray engine with Genesis 8 Females (Victoria, Luthril, Iska...) and G8 skins, clothing, and hair. This hair is Claudia Hair for Gen 3/8. I also have a dress with lace mesh and the skin underneath turns green. I have tried all of the adjustment dials for this hair. I can get rid of the green by lowering the headsize dial, but then the hair at the scalp looks even more awful and some of it disappears. Hiding the head node for the hair also makes the scalp visible and some hair disappears. I tried getting the Altern8 shader to see if that would help, but the green just becomes a flat brown that still looks awful.
Please help. Thank you!
Does https://www.daz3d.com/forums/discussion/309126/help-strange-green-texture-after-applying-hair help?
I haven't tried using the Beta version, but none of the rest helps...
In the discussion pointed by Richard there are workarounds. You can either turn off tranlucency in the g8f skin or make the scalp invisible with the geometry editor.
Then those are workarounds and this is a known bug that's around forever. So it seems daz can't find a solution.
I must've missed the geometry editor suggestion. Will check again.
