lipsync issues?
FetitoFetito Posts: 481
I was reading around the forum and I am a little bit confused:
1) So far as I read, there is still no 64-bit lipsync plugin for DS?
2) "Mimic Live" does not use pre-recorded sound-files
3) Mimic is compatible with Genesis 2?
Therefore, I am curious if the Carrara version of Mimic lets me save a facial morph which I can use within DS:
is there another Face-animation software compatible with the Genesis figure?
  • JaderailJaderail Posts: 0
    I just use DAZ Studio 32 bit beside the 64 bit. Works just fine.
  • FetitoFetito Posts: 481
    How can I export the facial morph so that I can use it inside of the 64-bit version?
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,310
    save the lipsynced figure as a scene
    edited November 2013
    Why? I just use DS 32 to render those and DS 64 for bigger Fuller scenes. I then Splice my Render files in my editor. I render to Frames I never Animate to a Full Ani File it fails to often.
    But yes as Wendy says DS 64 will read the Scene, I use the SAME content folder in both versions.
    Post edited by Jaderail on
    @wendy♥catz and Jaderail: Good idea! Thanks!
    Ah I forgot to ask something: What about "Mimic Live"? Is it good to add facial expressions? (I know that you cannot use recorded sounds).
    Moreover, is there another (external) Face-animation software compatible with the Genesis figure?
