G8F morph Bug [ Resolved ]
RemiFavRemiFav Posts: 1
Hello,
I allow myself to post a message because I have a problem with my Daz 4.10 pro. Indeed, I have a problem especially with Genesis 8 Female only. I start daz, no particular message, I go to the character tab, I select for example G3F or G2F, my character is loaded correctly, no deformation. I'm going to select G8M, no problem either, for cons, I run G8F or another character using it (Victoria 8 for example), it loads, no errors but however, it is completely distorted. I tried uninstalling it and reinstalling it with Install Manager but nothing changed. A few months back, G8F was working properly, I do not see where the problem can come from, usually I use G2F or G3F and I wanted to test Victoria 8 that I just bought, I noticed this problem. What do you recommend that I do ?
I attach a photo and my log file.
Cordially.
txt
txt
log Daz.txt
1M
Post edited by RemiFav on
  • Richard HaseltineRichard Haseltine Posts: 111,430
    Please make sure you switch the Viewport to Smooth Sahded mode before taking a screen shot of a nude figure.
    This is an issue with an add-on character - it has been saved with a non-zero default value. If you go to the Parameters pane and look at the Currently Used group the morph involved should be listed - just zero it. If it's a store product please report this as a product bug, if it's a freebie you can try contacting the maker to get it fixed or you can remove it or you can save a corrected version of that morph: click the gear icon on the slider and select Parameter Settings, chnage the Default Value to 0 and click Accept, File>Save As>Support Assets>Morph Asset, select just the morph in question, and use the same vlaues for Author adn Product as the original so that it overwrites.
  • RemiFavRemiFav Posts: 1
    edited June 2019
    Hello,
    Thank you for your quick reply.
    I flew over the Shaping in the G8F Parameters tab and saw some of the assets, I would look at it more closely tomorrow (10: pm here ;) ). Thank you and I'll let you know.
    Edit : I finally found the problem. A Morph entitled Alien Head, Alien Torso and Alien Torso and legs. I did not succeed in the lock so I deleted the files and G8F works properly. Thank you.
    Cordially.
