Help restoring the look of DS 4.11 Beta (problem cured)
Blind OwlBlind Owl Posts: 504
*sigh*
I know better than to use DIM while DAZ Studio is running, but this time I forgot to shut it down. Unfortunately, today's updates included a new version of 4.11 Beta, which now looks like this (see attached screenshot).
I've tried loading a saved workspace, and even did a System Restore, but neither made any difference. Do I need to uninstall & reinstall 4.11 Beta? If so, is there anything I should do before I proceed?
Thanks in advance.
1920 x 1080 - 332K
Post edited by Blind Owl on
  • Richard HaseltineRichard Haseltine Posts: 111,430
    Uninstall and reinstall the application - this is one of the rare occasions when that is the solution.
  • Saxa -- SDSaxa -- SD Posts: 882
    edited June 2019
    Got the same for the same reason.
    What you are seeing is actually still Beta .380.  Check the "about Daz Studio" under help.  Fix was easy.  Close DIM.  Start new session of DIM. And you should automatically see the Beta listed again as available to install, as if it never installed to begin with.
    Or that's what I got when I got same white screen.  Wasn't sure with uninstall if I lose any of my customizations as my Public Release is setup way different, so was happy it worked like that.
    Post edited by Saxa -- SD on
  • Blind OwlBlind Owl Posts: 504
    Whew! That did the trick.
    Thanks for the help. Note to self: shut down DS before you fire up DIM.
