Gizmo And Object No Center
hello,
when I import an OBJ object, it is not centered.
The GIZMO is shifted.
How centered the object and place the GIZMO on the object?
thank you
hello,
thank you
What software are you importing to, DAZ Studio? It will depend on where it was when the OBJ was saved in the original application
In DS you can use the Joint Editor tool (Alt+Shift+J) to move the gizmo to where you want it to be.
thank you JimmyC
I used Rhinoceros to export my OBJ file.
When I import the file in DS, I chose France.
But the object is not placed in the center of the grid.
It is very far outside.
How to place the object at the zero point of the grid?
Use the Transform sliders in the Parameters pane, move it to 0,0,0
You can zero the sliders by clicking on the slider while holding down the Alt key. Hope that helps.
