ZBrush 2019.1 and Goz
Hello guys. I used Goz normally with Daz in the 2018 version of Zbrush. I upgraded my zbrush to 2019.1 and today I was using Goz for the first time with this version and Goz is not working with Daz. Someone with this problem too?
  • IsaacNewtonIsaacNewton Posts: 1,300
    The GoZ connection between DS and Zbrush is notorious for giving problems. Check out all the GoZ related threads that have been posted in this forum.
    First step is to check that your GoZ version matches your DS version; look in the About menu and the Plugins menu, the last digits of the version numbers should be the same.
    Even when properly installed GoZ will, from time to time, just stop working. This has been reported as a bug many times over many versions of DS and GoZ, but has not yet been solved.
    The work around that I use is to use DIM to uninstall DS and then reinstall DS. Note, you may have to delete the DS package after uninstalling in order to get a proper reinstallation.
    One other thing you can check is to make sure the GoZ path from Zbrush to DS is correct. Look in Preferences in ZB. Normally this is fine but it is wise to make sure.
    Good luck and maybe you should report this as a bug to the Help Desk; one more voice might help spur some action.
  • Richard HaseltineRichard Haseltine Posts: 111,363
    Has the ZBrush 2019.1 installation gone to a different application folder from the original?
    "Not working" is a bit imprecise - is the menu command in DS missing, if so check help>About Installed Plug-ins for itss tatus and perhaps try some of IsaacNewton's suggestions. If the command is there but not operating try resetting the path in Zbrush - from its (preferences>)plugins menu (sorry, I can't recal the exact location).
