rendernode 8.5 : lense flare not showing
DonleavyDonleavy Posts: 34
edited November 2013 in Carrara Discussion
Hi
I tried rendering using two machines and RenderNode. Everything worked out great - except my lense flare effects (on a bulb light) didn't show up at all on the renderings on the slave computer, thus rendering the rendering useless.
Anyone tried this? Should I perhaps open a bug report?
Br, Dl
Post edited by Donleavy on
    Unless something radical changed in the 8.x releases, the lens flare is a post render effect and should be generated on the host machine. Unfortunately I don't have a version of Carrara later than C7.2, so I can't test it.
  • DonleavyDonleavy Posts: 34
    wow, that really makes it difficult to use the RenderNode easily if post effects are used in the animation...
    How do you have the network render set up? In C7.2 Pro it was very basic. You had no control of what the nodes rendered. In C8.0 changes were introduced to the network render option that gave the user some options, but like I said, I don't have C8.x so I have no idea how they were implemented.
    I can't see any options that has to do with the render settings. Only general settings. It's completely stupid, if the RenderNode can't render post effects…Then it's useless to me….sigh...
  • edited December 1969
    Did you copy your extensions folder from Carrara into your Rendernode? The most common reason for a rendernode to render differently is that the extensions folder hasn't been copied? The extensions folder should be in your Program Files/Daz 3D/Carrara8.5 (or similar) location.
    Copy that to your rendernode's extensions folder, then try again. You might need to restart carrara and the rendernode for the new extensions to be picked up.
    Boojum the brown bunny
    Actually, all the extensions are already in the RenderNode extensions folder - including lense effects….
    Still, the lense effects don't render on the RenderNode...
    Just to eliminate any possibilities:
    Is the bulb light within an object, such as a light bulb model or some other object that's supposed to emit light?
    No, it's just a light with lens effects. It renders just fine on my main computer, but all the images rendered on the slave (via RenderNode) comes up without any post lense effects. I can also see that the post effect progress bar don't show when the images are rendered on the slave (network). So annoying.
    Hopefully someone with C8.5 that uses render nodes can test this to see if they can reproduce it!
    Speaking of reproducing, can you create another scene and repeat the problem?
