MakeUp No mask On the face.
h2oliveh2olive Posts: 8
[MakeUp No mask On the face.] Help me
  • Richard HaseltineRichard Haseltine Posts: 111,430
    Moved to technical Help as it seems to be a question rather than a product Suggestion, though it's not clear (and please make sure you include the question in the body of the post, not just the subject line).
    If the issue is the mismatch between face and body, make sure that the make-up you are using is for the character used on the rest of the body and that theya re the saem material type - 3delight (RSL) or Iray (MDL). Some make-up sets are overlays, which should work with any texture set, but most work by replacing the clean skin texture with a texture that icnludes make-up.
  • h2oliveh2olive Posts: 8
    Thank you very much :)
