Are splats working in C8.5 Pro
Mosk the ScribeMosk the Scribe Posts: 908
Thought I'd use a splat for an irregularly shaped object - but nothing is showing up inside C8.5 Pro.
I can add a splat to the scene and see it listed under Scene Instances. Can focus the camera on it.
But nothing renders (and nothing shows up in my display)
Changing the shader to a color or an image texture doesn't help.
Visibility is on.
Is there something else I need to do?
Thanks
  • ncampncamp Posts: 345
    I just tried one. I inserted a splat. Went to the shader room and changed the texture to an image map. Rendered fine.
    In the assembly room, it just shows up as a bounding box, but it does render for me.
    8.5 Pro Build 243
    ncamp
  • Mosk the ScribeMosk the Scribe Posts: 908
    Hmm. I just opened a new scene and it renders okay there.
    Opened up the scene I was working on, added another one there, and still can't get it to show up or render.
    Maybe something in your render settings is different between the two scenes?
    Just found another problem where my alpha had been set down to 0 - I must have inadvertently changed my default shader in the scene to that, so new ones being based off that all started with alpha at 0.
    Thanks for the help. Fixed now.
