Help with tattoo using L.I.E
Hi all,
I have made my own tattoo design to be placed on the middle of the back of the model i am using. I can never get the alignment right, and it would end up having the middle of the tattoo overlap or ending up with a gap. Is there a template I could use to correct the alignment or is there a method I should know about?
  • Richard HaseltineRichard Haseltine Posts: 111,430
    You can export your own template from most modelling applications - I'm pretty sure Hexagon can do it. Don't change the mapping, just export the template. That said, the middle of the back is on a seam and is somewhat distorted so, if rendering in Iray, you may want to look at using an Iray Decal to project the tattoo image onto the model regardless of mapping.
  • dijitaqdijitaq Posts: 5
    Will look into that. Thanks for the tip.
