Calling all Carrara 8.5/Windows 8.1 users
Akulla3DAkulla3D Posts: 131
I have been using C8 with win 8 for a couple days and have noticed some wierdness with Gen 2 and runtime folders. They done seem to save and need to be reinitialed everytime I use an item. Anyone have any experience or know of any issue or concerns.
Thanks all.
Roger
  • PhilWPhilW Posts: 5,162
    Not had any issues with Carrara 8.5 with Windows 8.1, but I did find out too late that Poser 9 won't work with Windows 8.1. The response I had back from Smith Micro was that they are not supporting Poser 9 under Windows 8.1 and that I would need to upgrade to Poser 10. I made the alternative decision to delete Poser.
  • Akulla3DAkulla3D Posts: 131
    Hi all. Just moved up to Windows 8.1 and having some issues. If you are using Win 8 let me know so i can ask you some questions about some stupid issues I am having.
    Thanks.
  • SpacelandSpaceland Posts: 132
    I use Windows 8.1 on all my computer, desktop, Laptop and tablette.
    I have Carrara 8.5 Pro installed on my desktop and laptop.
    At the moment, everything i do in Carrara work correctly, but i am not using it often, real life issues goes first.
    What i do at the moment is more testing in carrara for light setup.
    Forgot to say,
    When i update from 8.0 to 8.1 for Windows, i uninstalled everything that was carrara.
    Then i installed Carrara 8.5 pro manually.
  • FetitoFetito Posts: 481
    Carrara 8.5 works perfectly on my Windows 8.1 machine. On Windows 8.0 I had issues with the DPI-fonts.
    Humm, do you use DAZ content?
    Yes, Michael 5 works perfectly. I was able to change his skin. Moreover I was able to add props.
    I was eben able to animate some blood-particles on his skin. (yay!)
  • Design AcrobatDesign Acrobat Posts: 459
    Use it, abuse it, ride it hard and put it away wet.
    Carrara 8.5 Pro can handle it.
    edited November 2013
    Akulla - what issues are you having? If you can specify it, we can maybe try to duplicate to see if it is also an issue for others or not? I am using Win8.1 with C8.5 and it seems good so far.
    Post edited by PhilW on
  • StezzaStezza Posts: 9,212
    I bought PoserPro 2012 in March when it was discounted..
    now 8 months later they don't support it!!
    That was $150 wasted... lost me as a customer.
    Seems to me it would be a bit better to have one thread, than two threads about essentially the same thing by the same person.
    Agreed, I have merged the two threads, so all the answers are in one place, to avoid duplicating information in two places.
    Post edited by Chohole on
    Not sure why but I was having a problem when adding a morph to V6 or Josie(using smart content tab) as it threw a pop up box error that just said error and nothing more for why it happened. It is working now as I added the new content as a folder under normal content tab and the error stopped. It appears it was looking for something that it couldnt find probably some path issue. Once I also added it to content tab it worked. I will try doing some screen caps.
    Why are people posting stuff about Poser on this thread as this is a carrara thread.
    Probably because there are quite a few Carrara bashers that complain about its support. PhilW was commenting that he had better support from DAZ with Windows 8, than he did with Smith Micro. It's a bit off-topic, but still within the the realm of conversation.
