G3m distortion in sitting position
I'm not sure if this is a new problem or something I've only recently noticed, but when I move the legs up on a Genesis 3 Male figure (or a figure based thereon), there are major distortions that occur. There appear deep grooves at the top of the legs, and the belly squishes up and forms a sharp ridge down the centre. Is there a way preventing or fixing this? (I thought it was a result of a particularly muscular morph, but it seems to happen with all variations including the standard figure).
Image removed
  • Richard HaseltineRichard Haseltine Posts: 111,332
    Please switch your Viewport to Smooth Shaded view before taking a screen shot of a nude figure.
    There have been a couple of products that do this, I think - there's a morph to correct the bends when a radical shape is applied to the figure but it is kicking in for all bends, even if the morph isn't applied. If you select the figure and in the Parameters pane option menu enable Show Hidden Properties (the lined button in the top corner, or right-click the tab) then by selecting the Currently Used group you should be able to identify the culprit.
  • Thanks. That helped. It seems there was a morph (the freebie Hotei, by Mythcons, a fat Buddha-like figure) that was causing this distortion in all other figures. Deleting the files for that morph has stopped the distortion occurring with other G3m figures. Apparently there is an updated version of Hotei availible so possibly it doesn't cause this to happen any more, but I haven't tested that).
