Would like some tips on lighting.
Hi. I have been working on this Faberge egg for a while now and have everything pretty much how i wont it. But would love to know how I can get a little bit of lighting on the figures faces in the egg without making everything to bright.
1100 x 1188 - 1M
  • LinwellyLinwelly Posts: 6,070
    Which render engine are you using 3delight or Iray? as well what kind of light are you using right now?
    If for Iray I would just start with a simple place turned to emissive with a light temperature about 4500 °C swithch to kcd/m^2 Luminance units with 1500 in the luminance
    For 3delight I would start out with two spot lights from above
  • FirstBastionFirstBastion Posts: 8,087
    If you placed an emmissive plane on the ceiling of the room pointing downward,  you would get a nice balanced light and you can control the intensity to suit your tastes.
  • FishtalesFishtales Posts: 6,238
    Or just use the ceiling with the diffuse image in the emission colour map.
  • RakudaRakuda Posts: 938
    edited May 2019
    @bastian2560 This is a pretty good product
    https://www.daz3d.com/ptf-neon-splash-lighting-suite
    Depending how you rotate your dome you can get varying results.
    Edit: I deleted my home made example as I realized it wasn’t yielding the same results as the product above. Likely because that was an HDR dome. So that gives me something also to figure out how to render light setups to an HDR dome...
    600 x 776 - 227K
    Post edited by Rakuda on
  • bastian2560bastian2560 Posts: 85
    Hi. Wow, thanks guy's for your qick respons. i have tried every thing sergested and did not get the resuls wonted. i have tried to duplacate the shadows from my scors pictures.
    What i had to do in the end was cut the top of the egg and render it then mix and match in post work. At the end i ended up with somthing close to what i was after.
    800 x 800 - 82K
    800 x 800 - 552K
    800 x 864 - 385K
    Opp's forgot. i used iray and all iray shaders. I also had to make my own HDR. final product.[i did not make the egg i fond it somwhere]
    800 x 400 - 67K
    1500 x 1620 - 3M
