Auto fit broken keeps getting worse
BobvanBobvan Posts: 2,653
edited November 2013 in The Commons
When Genesis 1st came out real world police used to auto fit with no problem. Then the pants would not work right now this....
1600 x 851 - 49K
Post edited by Bobvan on
  • Richard HaseltineRichard Haseltine Posts: 111,984
    Which shape are you using? Is the Content Management Service running?
  • BobvanBobvan Posts: 2,653
    Yes the CSM is running I attempted to auto fit it to m4 like I said it used to work what settings should I be checking? Other V4 stuff still works. I did re download the content made no diff.
    Using Genesis with David 5 and a touch of Sticky, I get this - a bit of poke-through on the left shoulder and soem self intersection on the left collar but nothing like your issues.
    462 x 953 - 49K
    Interesting
    Ah, so you are using the V4 version of the clothes on the M4 shape. Let me try that - I used the M4 version of the clothes in the above image.
    OK, this is the V4 version of the uniform on the M4 shape for Genesis - if anything ti seems better than the M4 version.
    462 x 965 - 49K
    How do you set it using the m4 shape? Anyhoo I think part of the issue was trying to use it on a pre saved character so I loaded it in on a fresh genesis not as bad but still having the same issues with the pants I previously mentioned.
    1600 x 851 - 54K
    The pants issue looks as if it got confused about which bit of mesh belonged to which leg, probably because there's some crossing in the geometry once it's reshaped for Genesis - but I don't see that. I'm using the current release version, 4.6.1.33, with the loose pants option for clothing type.
    I did the same why would it work for you and not for me... In any case makes it so that I am not getting rid of Gen 4 anytime soon..
