Victoria Base 4.2 Question
KeithHKeithH Posts: 338
The DAZ Install Manager shows it is installed.
I do not see anything having to do with Victoria as an option. How do I find the models that have been installed?
Thanks
  • Richard HaseltineRichard Haseltine Posts: 111,688
    In Daz Studio? Where are you looking, and which packages did you install? Remember that Victoria 4 is Poser-format.
  • GoggerGogger Posts: 2,535
    You'll need to go looking in the following path of your content library in DAZ Studio:
    \Poser Formats
    \Figures \DAZ People \Victoria 4.2
    She should be about the last item.
    My library is all DIM installed (except for stuff I buy elsewhere).
    Hope this helps.
  • y3kmany3kman Posts: 895
    If you have the updated metadata, Victoria 4.2 should be available in your smart content tab.
    Smart Content -> Figures
    Content Library -> Poser Formats -> My Daz 3D Library -> Figures -> DAZ People
  • MisselthwaiteMisselthwaite Posts: 961
    Usually you can find it in your Daz Products listing, under Victoria 42 base.
  • KeithHKeithH Posts: 338
    I never got notifications to the replies so did not see this till now. I figured it out. New to this and learning as I go. Thanks
  • davesodaveso Posts: 8,308
    so how did you figure it out? where?
    Smart Content
    Products (not Files)
    Figures - At the bottom choose All - Some will be greyed out with an odd icon. Right click and choose install
    Then everything appears where it is supposed to be.
    Smart Content
    great. thanks smiley
    That sound alot like you're using Connect.  The 4th generation figures must not be installed by Connect, their ExP morph system wont work with Connect's folder structure.
