Render only a little part of the image, is there any way to do it?
I rendered an entire image, but I've made an adjustment, now I just want to render a face instead of all body. Is there anyway to do it? Spot render tool does not export file as far as I know!
Thank you guys!
Post edited by raphaelmartines on
  • barbultbarbult Posts: 27,500
    When you have the spot render tool selected, go to the Tool Settings pane and choose to New Window. Then drag the spot render tool in the viewport to outline the area to render. This is handy for rendering a small area after you fix some trivial detail. Then you can composite the spot render into the main image with an image editor like Photoshop, without having to rerender the whole scene.
  • Seven193Seven193 Posts: 1,156
    edited May 2019
    Thanks, I didn't understand this until I actually tried it out. It's not very obvious.
    Tools -> Spot Render
    Window -> Panes (Tabs) -> Tool Settings
    Active Tool -> Spot Render
    Render To: New Window
    You will still drag the mouse in the viewport, but this send the results to your render window (setup in Render Settings).
    Post edited by Seven193 on
  • Thank you, guys. It were very accuracy awnsers!
  • rrwardrrward Posts: 556
    Oh, and when you bring the rendered image into Photoshop (or whatever program you're using), flatten the image before you copy and paste it over the original, then cut away the white frame you don't want. This will drop the new rendered section directly on top of the old section without having to finagle it into position.
  • mark_z2487mark_z2487 Posts: 125
    Thanks, the new window is an important part I would have never found
    On the tip to flatten the image, rather than flatten, paint or fill the upper left and lower right corners, that will locate the pasted image, easer to remove, especially important if not a rectangle
