Importing 2d photoshop images to DS
Is it possible to import a 2d image in some format that then can be used just like a regular object but of course fits physically only in the two planes?
  • LindseyLindsey Posts: 2,016
    edited November 2013
    You could create a plane primitive and apply an image to it in the Surfaces tab.
    1. Create>New primitive
    2. Select Plane Type, adjust size if desired. Click Accept
    3. Adjust the position, rotation, and x and y scale using the Parameter tab's translation/rotation/scale controls
    4. To apply a texture, with the plane selected, go to the Surfaces tab and add an image to the Diffuse channel.
    600 x 645 - 111K
    Post edited by Lindsey on
  • Virtual RealityVirtual Reality Posts: 0
    Thank you! I do not know why I could not remember how to do that and you helped clear up a mystery in Photoshop where I created a 3d object out of the image but it did not associate the "texture" which I found as a result of your post.
