DEL!!!!!!!!!!!!!!!!!!!!!!!!!!!
a0000100sa0000100s Posts: 13
edited July 2019 in Daz Studio Discussion
Post edited by a0000100s on
  • Richard HaseltineRichard Haseltine Posts: 111,994
    Save Modified Assets should not be used without caution. If the default values of the original morphs have been changed then a simple reinstall of the content should fix the issue - try uninstalling/reinstalling one as a test and see if it gets better. If not I suspect that there is a single rogue property that is driving all the others to 100% - try one of the standard morphs, on its slider click the gear icon and from the menu select Parameter Settings; in the dialogue click the Controllers tab; what is listed there?
  • a0000100sa0000100s Posts: 13
    edited April 2021
    But does it fix the things you reinstall? And if not have you looked at the Controller list as in my last post?
