Forgotten Prop File Path Location Lookup.
I have loaded a scene that I created over a year ago. The scene contains a prop that I want to find again in its content map folder through the content library. The issue is that I have bought many items and freebies since then, and forgotten the assets location. I know that I can run a search for the file name since I am able to read it on the scene tab and nod info tab, however running a search through daz takes my computer a while to go through all of my asset owned. Is there a way I can select the prop in the scene tab and pull up the property listing with the file path location of the actual prop file? As of now I just see the meta data Scene ID : Content Type : Compatibility Base : written out which is useful but not what I need at the moment. Thank you all in advance.
Rob has a sample script that will list the assets used http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/metadata/list_products_used/start
