Please Suggest Me A Card From These Option
ModelcraftModelcraft Posts: 58
Hi, I am planning to go for Nvidia 1060 3GB Version. Simultaneous multi-projection, Nvidia GPU Boost 3.0, 1152 CUDA cores, 3GB GDDR5 memory, 192-bit memory bus, Engine Clock: 1506MHz (Base)/1708MHz (Boosted), Memory Clock: 8GHz
It's under my Budget also.
I mostly do Static Renders under 1200 by 800 Resolution, With One or two characters and take about 1 - 1.5 hrs under Iray CPU Mode. Sometimes I do by four. Max I did was 5 and it took 1.5 hrs on 3D Light.
My System is AMD Ryzen 2400G With 8 GB DDR4 RAM. Daz in installed on a Samsung SSD. I do not overclock.
The second Option is GeForce GTX 1650 OC Edition 4GB GDDR5, GTX 1650 OC comes with ‘896 CUDA cores’ and operates across a 128-bit wide bus interface at speeds of 8 Gbps.
The last card which one is in my budget is  GeForce GTX 1050 Ti, 768 CUDA cores, 4GB GDDR5, 128-bit Memory Bus, 1392 MHz Base, 1506 MHz Boost, 7 GHz Memory Clock
Post edited by Modelcraft on
  • Richard HaseltineRichard Haseltine Posts: 110,801
    3GB is very limiting. Certainly I would think the 4+ figue scenes, especially if they have hair and clothes, would be pushing it. Reducing map sizes or simplifying materials might help.
  • ModelcraftModelcraft Posts: 58
    Yes, But what about if I do max 4 characters. Also, 1060 one has more Cuda Cores.
    Other two got less Cuda cores and I think Cuda cores matters a lot.
    CUDA cores (within a generation) are an indication of speed. However, if the card isn't used due to lack of memory then they won't do anything.
