BETA 4.11.0.236 on laptop with USB monitor: Dials with large ranges get stuck on
I've noticed a very specific issue in the 4.11.0.236 version of the beta. When I have a dial that has a large or infinite range (X/Y/Z rotations/translations or figures with limits off), if I grab the point and slide it the selected property will just start going that direction at an unexpectedly high rate. If I stop dragging it will stop, but if I drag the other direction while still holding the slider it will continue the same direction and not course correct.
If I restrict the range the symptoms are reduced. A good example is a figure's Y rotation. Leave it unbounded and try to adjust the rotation and the figure will spin out of control. If I set the range to 0 - 360 I can control it as expected.
I have the same version on my home PC and I do not experience this issue, only on my laptop.
