storyboard with DAZ
Hello
firts sorry for my english. I am fench guy
how to create a storyboard with daz? there is a tutorial somewhere?
thank for your help
  • Richard HaseltineRichard Haseltine Posts: 111,325
    I thought a storyboard was a sequence of images? In which case I'm not sure what you are looking for beyond the ability to render images. If you want to keep everything, at least for a given scene, in a single file you could try loading all the content, setting a frame up, then advancing the timeline (Window>Panes(Tabs)>Timeline) a notch, setting up the next frame and so on - but if you need more content for the scene in total (comings and goings) then that's going to be more taxing then doing single images.
  • LoicoLoico Posts: 16
    ok! thanks you!
    before I used to work with frameforge.now I am looking for a better sofware
  • twitchewtwitchew Posts: 127
    i looked at all the things core does in terms of script and camera work. i think daz would make one scene but not do any of the more integrated work for previualization, scripts, cameras, lighting and shooting scheules.
    tooo bad! thanks your for help!
    I keep looking for...
  • I am looking for something lik this as well to work with daz3d I even bought carrara for its storyboard thing but its currently broken with Huion drivers and they are not gonna fix it. anyone else know of any good plugins or scripts to setup different storyboard stuff in daz?
    edited September 2025
    Hello
    I would like some help on how to take a snapshot of camera's frame.
    thanks
    Post edited by Loico on
  • Loico said:
    Hello
    thanks
    I am not sure what you are asking?
    I need help taking a photo from the image displayed by the camera.
    If you don't want to render try File>Save Last Draw
    so Getting only the camera frame is not possible
    And how do you set up the camera to shoot in Super Panavision 70 (2.2:1) format?
    There are a variety of preset aspect ratios in the Editor tab of Render Settings, if it doesn't include that one turn off the cosntrain aspect button, enter the ratios in the widt/height boxes, and optionally use the Save... button to add it to the list.
    You can set the Render Engine to Viewport and then render, that will be faster than the full renders (usually) and will respect the render dimensions.
    thanks
