Easy Way To Create Broken Glass?
Hi everyone!
I need to create a shattered crystal ball, and so I need to create some broken glass or something like that.
I've seen these shaders: https://www.daz3d.com/colored-and-broken-glass-iray-shaders
But I don't think they would achieve what I want.
The other products are too expensive for me right now, sadly.
There's this freebie: https://sharecg.com/v/66942/view/5/3D-Model/Shattered-Glass
But it's more for broken windows, than for a pile of broken shards on the ground.
So, do you know any easy way to create that myself? I'm not a modeler at all!
I had thought about creating some primitives with the glass shader and shattering them around, any better idea?
  • LeanaLeana Posts: 13,593
    edited May 2019
    If you need something cheap, this breakable window freebie might work to create shards on the floor with a bit of scaling / positioning.
    Otherwise I would suggest this product which includes glass debris (both flying debris and on the floor).
    Combine those with a DS crystal shader since you want crystal shards.
    Post edited by Leana on
  • LenioTGLenioTG Posts: 2,118
    Thanks Leana :)
    Yes, that looks like the perfect product, but right now I can't buy it! Maybe I'll render that scene again next month with that product.
    I think the other freebie looks a little bit better!
  • chris-2599934chris-2599934 Posts: 1,984
    If your crystal ball is a solid one, then smashing it is likely (I imagine) to produce a load of irregularly shaped chunks of glass, rather than the flat pieces you get when you break a window. I think I'd be looking at products (and freebies) intended to represent rocks, like say this one: https://www.daz3d.com/rubble-for-everyone-vol-ii . Apply a glass shader to the rocks and you should have something close.
    Thank you very much, this is a great idea!!! :D
    This is what I had achieved with that freebie, but, of corse, it's not ideal :(
    887 x 658 - 2M
    Okay, perfect, this looks much better now!!! :D
    The crystal ball was actually red.
    I've used a rock freebie from sharecg, and some other rocks I had in my library, and applied the shader
    1053 x 753 - 1M
    edited May 2019
    Pretty convincing :)
    Thank you!! :D
  • 3WC3WC Posts: 1,167
    Try a baseball bat or 9 iron on any window!
    (Sorry, couldn't resist.) ;)
    Alright xD
  • lukon100lukon100 Posts: 855
    I love the glass-shaded rocks trick.
    Yes, shoutout to Chris, it worked for me! :D
  • These are Ps brushes but might help...
    https://www.daz3d.com/ron-s-broken-glass
    Thank you :D
    But I've already done that page, I didn't have the money to purchase anything, I don't know how to use them and I think the rocks look better ^^
