Son of M6
Over two days I have made a variation of M6.
Readapted textures from M4.
Morphs and adjustments from Zbrush.
Saved the scene with all in it.
Can I save the completed figure as something that can be reloaded
as a new figure. and not just open the scene.
Thank you.
That depends on how you're saving — with File>Save As in the menu bar, or clicking on the "+" button on one of the Content tabs (this is the preferred way to do it). Either way will give you lots of save options, I think the one you want is "Character Preset". This will save textures, morph and pose settings all at once.
Edit: I just realised from what you said, is this replacing your scene when you load it? Either re-save as a "Scene Subset" or load with a right-click and select "merge", and your figure will be added to anything already in the scene.
Thank you very much, will try.
Worked as save as character preset.
THANK YOU VERY VERY MUCH.
Too much work was put into this....
