Animating to different textures in C8.5 pro
Mosk the ScribeMosk the Scribe Posts: 908
I want to have a simple plane that changes from one texture / image to another over time.
I thought you just had to choose texture in the color channel, then navigate to the desired image; then move the current time indicator, and repeat the process to have the plane transition from one image to the next.
That's not working - whatever image I choose last takes over.
I do have Shoestring shaders which had a feature that let you do this - I'll have to find my notes to remember how - but isn't this a standard feature of Carrara? Am I doing something wrong or can't you animate from one texture image to another?
Thanks.
  • McGuiverMcGuiver Posts: 221
    Use "operators" - "mixer" in the color channel, then, choose a different texture for each source.
    Use value 0-100 as the blender.
    To change the texture, move the value over time.
    You can blend them, or use a discrete tweener in the timeline to make a sudden keyframe change in the texture.
  • Mosk the ScribeMosk the Scribe Posts: 908
    Thanks McGyuiver -
    that worked perfectly.
    Out of curiosity, is there a simple way to do this if you want to shift between 5-10 textures instead of just 2?
    (Shoestring shaders gives you that functionality, but I was wondering if you could replicate that in carrara with multiple mixers, each pair controlled as you described or if it would simply get too convoluted.
    Thanks
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,823
    yes use an image series, number them (image name n) and import as image series
    to get a fade can open the series in virtualdub, use box doubler filter few times and add motion blur filter, re-export as image series.
    to adjust speed or change use the slider under the map and keyframes produced from it.
    Thanks McGyuiver -
    Thanks
    Yes, you can stack the mixers & yes it can get complicated.
    I have Shoestring Shaders "Supermixer", but am not really familiar with it's use.....just haven't played with it yet.
