Daz crashing, computer crashing: ideas?
James_HJames_H Posts: 1,114
I haven't nailed down what is happening here, but I have been using Pose Architect to create poses: that seems to work ok for a shot + render.
If I then zero the Pose Architect pose (by manually returning each dial to zero), then pose again using Pose Architect & then manually adjust details using regular dials, I can then start a render, but when I come back, Daz Studio has crashed and in some cases at least the computer has rebooted.
Any thoughts about where best to start with this? I could reinstall Pose Architect, but I'm not sure if that's the problem.
    I have no experience with Pose Architect but if your PC crashes I would suspect it's more a PC problem than a DS one. Maybe you should post a ticket for the product if you think it's faulty.
    Perhaps your GPU RAM or on-board RAM is maxing out, or your PSU to your GPU isn't up to scratch for your card but it's impossible to tell without your specs.
  • James_HJames_H Posts: 1,114
    Thanks, worth thinking about. But unlikely, as I have a 1080Ti, 32GB RAM, and the PSU has generally been stable. But I will keep an eye on that. I need time to do some testing. When I just rely on poses and on posing myself conventionally, I don't seem to have the same problems.
  • PorsimoPorsimo Posts: 359
    While it's not unheard a plugin or script could crash DS, I very much doubt their ability to crash a PC. So, I'd say it may very well be a hardware issue, e.g. PSU or gfx card might be failing.
  • ArtAngelArtAngel Posts: 2,096
    I recently had crash issues but I max out scenes with large environments a dozen characters posed, clothes, not bald and they did render well but the same scene crashed repeatedly after updates. Not sure what changed but because Daz is not a stagnant program and embraces Nvdidea technology I decided to build a new system because I want to advance as technology advances. BUT I always create a restore point before downloading DAZ products via DIM because DIM sometimes updates and makes changes to your system. I never check install after download. I close DIM. After I set another restore point I install downloaded products. This to sometimes causes system changes. Whenever my system crashes I restore to an earlier point and all is well. For my PC#2 I will always create restore points. Couldn't render without them.
