Products missing or not working
Ruphuss
i use the productssection of dazstudio for categorizing
now i see, comparing with the productlist of DIM, alot of products (all of the gis series and more) not appearing under products in studio
Quel Bazar is not finding most items
Cliffhanger has no prop at all
I have six items in the GIS series, and all of them appear in Products and in the DIM as installed.
I don't have Cliffhanger or Quel Bazaar so I can't check those. You may need to reimport your Metadata if there are a lot missing
so the productsection is linked to metadata?
and you think reimporting my saved meta-data could help and do not spoil my hard worked categories
Reimporting metadata shouldn't touch any of your User Categories, but I always save mine before I do it anyway. Use Export User Data first (it can take a little while depending on how much you have saved), then use the Re-Import Metadata just above it to see if that works.
i will try
thank you Jimmy
products seem to be all back
so reimporting metadata worked fine
Quel bazar misses alot items though
Cliffhanger wants items in the Szene
animate Monster pack has no Content at all
Quel Bazar is just a texture set for Marakeh Souks which is a required item : http://www.daz3d.com/marrakesh-souks-2012
I don't have either of the other two, but Animate blocks should be easy enough to find, and I don't know about Cliffhanger, but it is a Jack Tomalin item, and you will get an answer from him if you post in the PC Members Forum.
thats right i could have known that
thx for your patience
Cliffhanger's DS files are only material settings. You should find the actual cliffs and such in your Poser directory as .cr2 or props. I had the same problem when I bought it.
Slosh thx for the hint
i will try
but it shoudnt behave like that
there are no poser files installed through DIM
after installing manually from the product library they appear
